AutoCAD 2010/2011/2012
New Member
Message 1 of 4 (243 Views)
Problems with plotting on larger paper size and "plot transparency"
243 Views, 3 Replies
02-04-2013 11:02 AM
Hi I have a canon ipf605 plotter. I try to plot to a custom paper size with the "plot transparency" and it doesn't work. Any ideas why not?
*Expert Elite*
Alfred.NESWADBA
Message 2 of 4 (230 Views)
Re: Problems with plotting on larger paper size and "plot transparency&quot
02-05-2013 01:37 PM in reply to: mouke
>> it doesn't work
...means what? Plotter does not get data, your workstation crashes, your server crashes, plotter gets data but shows an error message, ...?
Generally, plotting with transparency on means a lot more memory to be used. So I guess your plotter has not enough memory for processing the data. It may help to:
  • try to find an option in the driver named like "process on computer"
  • plot to file and send then the file to the plotter
  • plot to DWF and then print the DWF from DesignReview to the plotter
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
New Member
Message 3 of 4 (220 Views)
02-11-2013 09:52 PM in reply to: Alfred.NESWADBA
dear alfred, thanks for your replay at first let me explain, "doesn't work" means that i can see the printout on the preview but it doesn't print . That happens with every custom paper i tried to plot with "print transparency" (it works ok with the iso papers etc) It could be lack of memory but why it works with the standard size papers?
*Expert Elite*
Alfred.NESWADBA
Message 4 of 4 (216 Views)
02-12-2013 01:31 AM in reply to: mouke
I don't know what custom sizes you tried, if they are all bigger than the default sizes then it's a memory problem.
I would come back the "try to plot to DWF (or PDF)", if that works, use DesignReview (or Adobe Reader) to send it to the plotter ==> now again the question, does that work?
- alfred -
Alfred NESWADBA
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
