Hi, I have a little problem with graph from Excel in autocad. I have moved points from excel form autocad, but values this points are very low
for example (0.001, 0.00470123) or (0.054 13.70878668). So a graph is a little difficult to read.
Have you any idea how to fix it?
Greetings.
Solved by Patchy. Go to Solution.
Show us a snap shot of your graph as it appears on autocad screen.
What is (0.001, 0.00470123) or (0.054 13.70878668) ? coordinates? a point there and your PDMODE is setting at which one?
What is graph from excel in Autocad ?
I've made graph in Excel (1.jpg) and this graph looks in autocad like in 2.jpg.
This numbers is points coordinates.
Because autocad uses x,y on same scale, you have to make this into a block and insert it back to the drawing with different x and y scale factor.
