AutoCAD 2010/2011/2012
Member
jeffbeck
Message 1 of 10 (1,395 Views)
Presspull
1395 Views, 9 Replies
05-12-2010 12:51 PM
Any one have a problem using the presspull tool? I have used it successfully here and there but often invoking the toll crashes AutoCAD.
Alienware Aurora
Intel i7 920 @2.67 Ghz
9.0 GB
Win 7 64 bit
lawrencerobinson5
Message 2 of 10 (1,395 Views)
Re: Presspull
05-12-2010 01:23 PM in reply to: jeffbeck
This is not the fix reply you may be looking for, but I've had no problems with the presspull tool.
Lawrence
Active Contributor
tbus227
Message 3 of 10 (1,217 Views)
Re: Presspull
07-14-2011 07:01 AM in reply to: jeffbeck
I realize this is an older post, but I cannot get the presspull to work at all.
Dell Precision T3500
Xeon 2.8 ghz cpu, 6 GB ram
64 Bit Win 7
ATI FirePro V5800 (Fire GL) Video Card
Autocad 2011
*Pro
nestly
Message 4 of 10 (1,193 Views)
Re: Presspull
07-16-2011 12:21 PM in reply to: tbus227
Press-Pull doesn't work for me unless Selection Preview is enabled.  Tools > Options > Selection Preview (SELECTIONPREVIEW)
Give that a try.
Active Contributor
tbus227
Message 5 of 10 (1,176 Views)
Re: Presspull
07-19-2011 07:32 AM in reply to: nestly
Selectionpreview made no difference.  When I checked it, it was already enabled.  When I first installed autocad, I was able to get it to work.  I've made no changes that I can recall (which probably means that I made a change somewhere and forgot what I did).   I tried presspull one day and it didn't work and I haven't been able to get it to work since.
64 Bit Win 7
Autocad 2011
*Pro
nestly
Message 6 of 10 (1,171 Views)
Re: Presspull
07-19-2011 07:48 AM in reply to: tbus227
What does it say at the Command line when you start the command?
"Command: _presspull
Click inside bounded areas to press or pull."
Active Contributor
tbus227
Message 7 of 10 (1,169 Views)
Re: Presspull
07-19-2011 07:50 AM in reply to: nestly
Enter new value for SELECTIONPREVIEW <1>:
64 Bit Win 7
Autocad 2011
*Pro
nestly
Message 8 of 10 (1,161 Views)
Re: Presspull
07-19-2011 08:13 AM in reply to: tbus227
I was actually asking for the command line during PRESSPULL, but since SELECTIONPREVIEW=1 is only for when no command is active....try setting SELECTIONPREVIEW = 2 and see if that works.
Active Contributor
tbus227
Message 9 of 10 (1,155 Views)
Re: Presspull
07-19-2011 10:52 AM in reply to: nestly
That's it!  You know, I don't ever remember changing that specific setting.  I didn't even know about it until you told me.  Many thanks!
64 Bit Win 7
Autocad 2011
New Member
Listern
Message 10 of 10 (1,106 Views)
Re: Presspull
08-14-2011 12:18 PM in reply to: tbus227
I have been having the same issue, I have a complex drawing and the presspull function sometimes doesnt work at exact places, other times I can get lots done quickly.  Sometimes just zooming and viewing to another view point helps for some reason or restarting the program or other things as well, I tried  SELECTIONPREVIEW to 0, 1, 2, and 3, but it still seems to have the same issues, I've been grinding it out so far, but lately seems to be getting worse, with more complex drawings.  There are other things too that just seem to stop working at times, but I'll leave it with just presspull for now.  Need some help if anyone can, thnx.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
