AutoCAD 2010/2011/2012
Member
noengr
Message 1 of 8 (734 Views)
Plotting to PDF
734 Views, 7 Replies
12-13-2011 09:09 AM
When upgrading from a previous version of CAD to 2012, my list of plotters has been changed and I can not plot to PDF.  How can I add Adobe PDF to the list of plotters?
Alfred.NESWADBA
Message 2 of 8 (728 Views)
Re: Plotting to PDF
12-13-2011 10:00 AM in reply to: noengr
have you installed the oder version of AutoCAD or is it uninstalled?
If it's installed (and not to old) you can then start in both versions the plotter-manager and copy the PC3-files you need. Don't forget the PMP-files if there are any assigned.
- alfred -
Alfred NESWADBA
Member
noengr
Message 3 of 8 (721 Views)
Re: Plotting to PDF
12-13-2011 12:57 PM in reply to: Alfred.NESWADBA
Thanks for your reply.  The older version has been uninstalled so I cant use that method.  I am unfamiliar with the term PMP, can you please elaborate.
Alfred.NESWADBA
Message 4 of 8 (717 Views)
Re: Plotting to PDF
12-13-2011 01:29 PM in reply to: noengr
Ok, are you sure that all files are removed? Search your C: Drive for files with extension PC3 ==> if you find any that are not in an directory for AutoCAD 2012 you have a good chance to reuse them. Anyway one question first: what release was your old AutoCAD?
PMP is a file-extension for a file that is (optionally) used separately with PC3 (in this file are e.g. paper-sizes stored), if you open a PC3-file you can see if it points to a PMP or not (one of the last lines in the properties).
- alfred -
Alfred NESWADBA
pendean
Message 5 of 8 (696 Views)
Re: Plotting to PDF
12-14-2011 05:19 AM in reply to: noengr
You may need need to reinstall the "Adobe" driver you mention: if it is a Windows PDF driver, you probably forgot to turn on SHOW SYSTEM DRIVERS in R2012, but if that 3rd party PDF driver installed something for you in the old AutoCAD version then you probably need to upgrade it as well for it to see R2012 and do the same (unless a reinstall of that PDF driver will do the same).
Of course this begs the question: why not use the built-in PDF driver already in R2012?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
noengr
Message 6 of 8 (684 Views)
Re: Plotting to PDF
12-14-2011 08:30 AM in reply to: noengr
My previous addition was 2009.
Dean,
How do I access thebuilt in  PDF driver?  At the select plotter screen, there isn't an available option to select the built in PDF driver.
Alfred.NESWADBA
Message 7 of 8 (680 Views)
Re: Plotting to PDF
12-14-2011 09:13 AM in reply to: noengr
Hi
if you open the _PLOT dialog and open the list of plotters you should find an item "DWG to PDF". If you don't find it ....plus you don't find your system-printers while the check for it is on (like AdobePDF should show up) you have some troubles with your AutoCAD profile. If you haven't done to much customization to AutoCAD (or better you have saved it) then you can try to reset the AutoCAD profiles ==> find it in the Windows Startmenu.
Good luck, - alfred -
Alfred NESWADBA
Valued Mentor
tim.turner
Message 8 of 8 (670 Views)
Re: Plotting to PDF
12-14-2011 12:58 PM in reply to: noengr
Give the built in PDF driver a try. It is improved and actually works decently in 2012. Just use the Batch Plot function with your regular plotter page setup and pick PDF as your Publish To output. See attached.
