AutoCAD 2010/2011/2012
New Member
gobi.kastelic
Message 1 of 13 (3,429 Views)
Plotting an airfoil in AutoCad 2012
3429 Views, 12 Replies
01-15-2012 02:22 PM
Hi
I just downloaded AutoCad so I am very unfamiliar with it but I do need so help witha particular problem.  I need to be able to import the airfoil geometry of a NACA 2412 airfoil.  I know how to get the XY coordinates but I don't know how to import these points (as a .txt file?) into ACAD.  What function would I use?  Spline?  If so how do I get it to draw all the points I have?  I need to then extrude the shape to be able to mill airfoil sections...that part I can figure out....just need to import the points to get a nice curve.
Thanks for any (and quick :smileyhappy: ) help!
*Expert Elite*
Patchy
Message 2 of 13 (3,402 Views)
Re: Plotting an airfoil in AutoCad 2012
01-15-2012 09:17 PM in reply to: gobi.kastelic
Very easy.
Open that .txt file, highlight the coordinates and CTRL+C
Go to autocad, type in Spline or Pline command, when it prompts for first point, right click and Paste.
New Member
gobi.kastelic
Message 3 of 13 (3,397 Views)
01-15-2012 09:52 PM in reply to: Patchy
Ok, got it to plot  a good looking airfoil.  Is there a way to scale the airfoil?  Right now it is at an inch long, I'd like it to go to 6 inches while keeping the same shape - is this even possible since I input discrete numbers for each point on the curves?
*Expert Elite*
Patchy
Message 4 of 13 (3,389 Views)
01-15-2012 10:17 PM in reply to: gobi.kastelic
Snap a picture or attach your drawing here, I don't want to lead you the wrong way.
New Member
Message 5 of 13 (2,607 Views)
01-28-2013 06:56 PM in reply to: gobi.kastelic
i am attaching the coordinates file ......please tell me how to draw in cad with correct dimensions
New Member
Message 6 of 13 (2,605 Views)
01-28-2013 06:58 PM in reply to: kick507
this is diagram of airfoil.
*Expert Elite*
Patchy
Message 7 of 13 (2,586 Views)
01-28-2013 11:28 PM in reply to: kick507
Put texts in the correct format as shown, then command SPLINE, when it prompts for starting point, Paste the texts in.
Active Contributor
LaserGuy
Message 8 of 13 (2,562 Views)
01-29-2013 06:52 AM in reply to: Patchy
+1, and my 2 cents
Dell T7500
x5690 Xeon 3.46/3.73GHz
24Gb, SSDs, Quadro, Win7 x64
AutoCAD Mechanical 2014
Member
Message 9 of 13 (2,488 Views)
02-08-2013 12:24 PM in reply to: LaserGuy
I am in the same situation as the previous post. I have created my airfoil, but I would like to set it to 160 cm, How do I resize the object to scale this new dimension.
I have the image I created in order to understand where I am at currently.
JM
Member
Message 10 of 13 (2,471 Views)
02-09-2013 04:10 AM in reply to: jemo07
Hi again, also, when I try to do to a dimension, I can do it for just about anuthing, but not for a Spline, like the airfoil, How do I manage that also?
Thank you all in advance,
JM
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
