AutoCAD 2010/2011/2012
Member
Message 1 of 7 (200 Views)
Place and rotate
200 Views, 6 Replies
10-04-2012 06:27 AM
I work on mostly fire alarm drawings and for instance i have 4 different horn strobe symbols (one facing each direction) and i would like to make just one symbol that when i place it into a drawing i then after placing it decide what direction i want it to face. i am figuring that i need to do something when making the block that i am using. someone please help. Thanks.
Patchy
Message 2 of 7 (192 Views)
Re: Place and rotate
10-04-2012 06:36 AM in reply to: Mead8803
No need for anything special, when INSERT, it will ask you. Move the mouse and that's it.
Member
Message 3 of 7 (182 Views)
10-04-2012 06:50 AM in reply to: Mead8803
ok yea i know how to rotate objects but i need to have the letter inside of the object to stay while i rotate the object to whatever side i need it to be on. i want a block that i pull off my tool palette, place, and then determine what way the symbol will face, while keeping the letter inside the block facing the correct way.
Patchy
Message 4 of 7 (178 Views)
10-04-2012 06:56 AM in reply to: Mead8803
leothebuilder
Message 5 of 7 (166 Views)
10-04-2012 07:12 AM in reply to: Mead8803
Create a dynamic block
Valued Contributor
Message 6 of 7 (159 Views)
10-04-2012 07:54 AM in reply to: leothebuilder
Hi using a dynamic block is your answer.
I to work on fire systems & have now got one dynamic block to replace many standard blocks. I added a rotation action to the horn so that the central part stays the same as does the text & attributes. I did have to "play around" with it at first but now it works well.
I also added to the end of the visibility state name the part number of each type, added an invisible attribute made this a field which is the visibility state name so that you can get a list of the different types using data extraction.
Good luck took me some time but worth the effort.
Member
Message 7 of 7 (145 Views)
10-04-2012 08:29 AM in reply to: lesleys
thank you i will give it a whirl.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
