AutoCAD Forum
PLEASE HELP URGENT!
3 REPLIES 3
thierrygkhalil
370 Views, 3 Replies
PLEASE HELP URGENT!
When i open an auto cad file i get this message : There was a problem sending a command to the program then when it opens i can see the layers in the layer properties manager but can't see the plans!! BUT i can see them in the preview box from the automatic backup or on the desktop icon see the images please PLEASE I NEED HELP ASAP!!!!
3 REPLIES 3
welcome @forums.autodesk.com!
First of all please make a copy of your BAK file!
If you need the drawing repaired then the fastest option is to upload the DWG file and the BAK file.
A preview does not necessarily mean it's geometry in the drawing as the preview may have been created at another time.
You might also try to run command _RECOVER (or if XRefs are included run command _RECOVERALL).
Change to modelspace.
Next step is to verify all layers are on and thawed.
Then run command _ZOOM _EXTENTS in modelspace.
if you again see nothing make sure your property window is active (<CTRL><1>) and press <CTRL><A> to select all objects ==> what does the property window show now (how many objects does it see as selected.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
THANK YOU THANK YOU THANK YOU!!!!! the _RECOVER worked perfectly THANK YOU AGAIN!
You are welcome, thank you for your feedback, good to know it's solved now!
- alfred -
Alfred NESWADBA
”Boost
