AutoCAD Forum
PIn photo on solid face and crop
2 REPLIES 2
mendesva
390 Views, 2 Replies
Hy everybody,
I would like to "pin" a photo on a solid's face.
So, I pin 4 points on the photo and then move the pins to the corresponding edges of the solid's face.
The photo should stretch to fit the selected face and once done, crop the outside part of it.
Clear? Is it possible?
Using: Autocad 2012, Win 7.
2 REPLIES 2
Patchy
in reply to: mendesva
Crop your photo with another program then image it in autocad, make it a block and insert different x,y to fit the surface of the solid surface
(Assuming the surface is flat)
vivifira
in reply to: Patchy
or you can attach the image to a 3d face and manipulate it that way.... if you want to get fancy
”Boost
