Hi,.
I have attached a AutoCAD Drawing with this message,.
In that drawing, dimensions are in some settings like, ext.line color - red, text color - green,...
But all objects(lines, dimension lines, texts) are displaying in white color only,.
This drawing drawn in old versions (not sure which version)
But properties of the objects are as per settings (please see attached picture)
How to solve this issue,.
Thanks in advance,.
Solved by nestly2. Go to Solution.
Plotstyles override layer/object properties. "Display with Plotstyles" (monochrome) is checked in the PAGESETUP dialog box.
PAGESETUP > Modify > Display with Plot Styles
