Ok, from the beginning of time I have been able to pick on a line/object/block/etc., and the properties manager in the toolbar at the top of the screen would show that object's properties and I could change the properties of that object.
For some reason when I installed the program on a new computer, that no longer works. The properties of the entitiy I select do not show on the toolbar.
I cannot for the life of me find the command option to allow me to fix this.
Anyone please help!!
Solved by rkmcswain. Go to Solution.
Actually, if the PROPERTIES panel is completey blank there may a registry key missing.
Use a reg cleaner recently? Remove other ADESK products?
Anyway, if you the cure for that is to do a REPAIR install thru the Win control panel ADD/REMOVE and all will be well again.
You may need the disk, serial and activation code for this.
HTH
DJ
Unchecking the 360 module in the installer (as opposed to manually changing the deployment) can also produce this effect.
