Hi.
My Quick Properties does not show my block attributes but they shows in Properties Palette. I have edit Quick Properties in my Custom.CUI that overrides ACAD.CUI settings. I'm using AutoCAD 2012. Some suggestions?
Thanks in advance.
\Freddy
You may need to click the upper right corner of the QP window and Customize this dialog.
At the botton of the Editor that opens for Block Reference you will see Custom and Attributes.
Make sure both are checked.
And then look at everything else you can muck with.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi.
Thanks for any suggestions. There is no option for Attribute under Block Reference in the CUI dialog, see the attachment. We are using enterprise CUI and I try to make my own settings in the Custom.CUI that is located on my drive.
\Freddy
No attachment
Normal:
Expanded:
Customize:
CUI: Quick Properties sub menu
Hi.
I'm sure I attached the file. I try again.
I'm not able to attach a PNG file. I get this message: "The contents of the attachment doesn't match its file type". When I try BMP my Reply is posted without the attachment. So I'm not able to attach a bitmap file.
\Freddy
If you cannot edit as Charles has shown in his posted screenshots your CUIx is not complete or OOTB, but a very limited custom file.
Can't help you there, you'll have to restore a valid file.
What is the source of your local CUIx file? A modified ACAD.CUIx or someone homegrown at your office?
Of is it the block that needs fixing? Can you sare a DWG with the block in question for us to try? If you can, share your CUIx as well.
