I have 3D model that I have exported from Bentley SACS to a .dxf It looks like 3D solids but they are only polylines. Is there a way to convert these polyline shapes to solids or surfaces so I can use the view projection tools? I attached a sample beam .dwg for reference.
Solved by Patchy. Go to Solution.
Command: CONVTOSURFACE turn it to Surface
Command: CONVTOSOLID turn it to Solid 3D
