I am having this problem with my linetype text showing upside down. The thing is, when it is shown in model space, the linetype looks perfect. Even when i look at the linetype within a sheets tab, it is also perfect. The problem i am having is that in one specific sheet, I have the Y-axis or Northing axis viewport rotated to the left. That is when I get my linetype text showing upside down. Is there any way to configure this so that the text show the way i want it to show.
It will roatate with the view so if you fix it in the one, then all the others will be upside down afterwards. You could create another layer and draw a line in the opposite direction for that one view. Turn it off/Freeze in all views except the one where you need it.
@ejmartinez wrote:Hello,
REVERSE the direction of the offending line?
