AutoCAD 2010/2011/2012
Valued Contributor
Message 1 of 3 (115 Views)
Accepted Solution
Need help removing a MAP feature in ACAD dwg
115 Views, 2 Replies
12-12-2012 06:49 AM
Greetings.  I work with a colleague who is running AutoCAD MAP.  When he makes a block or saves a drawing, at the origin is a 3D, downward pointing arrow which in 2D plan view obscures anything around the origin.  I open his blocks or drawings in ACAD2012 or 2013 with the same issue.  In plan view, the 3d arrow appears as a circle with radial lines running out from the center.  If I save the drawing in my ACAD that feature is still there.
I've attached a png screenshot of what I'm talking about.
Is there any way to get rid of that feature, which is apparently coming from his MAP version of ACAD?  I've looked for settings on his machine and on mine.  I have played with the Workspace setting.  I've looked in Options for anything.  Maybe there is a system variable.  Does anyone know how to control the visibility of this 3D arrow in ACAD?
Thanks for any help.
Erik
Valued Contributor
Message 2 of 3 (112 Views)
Re: Need help removing a MAP feature in ACAD dwg
12-12-2012 06:57 AM in reply to: edweberg
GEOMARKERVISIBILITY command
Valued Contributor
Message 3 of 3 (104 Views)
12-12-2012 07:01 AM in reply to: Patchy
Awsome.  Thank you!
E
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
