AutoCAD Forum
Multileaders :: gap that occurs with DVIEW > TWIST
3 REPLIES 3
cgentile
373 Views, 3 Replies
So this happens when I define a twist angle for DVIEW and try to place multileaders. More times than not, I have the orientation of my viewport to maximize the content that is on a sheet.
This gap that occurs is only on one side of the multileader, and happens when I use two or more DVIEWs. For example, if I only use one DVIEW twist angle, this gap does not occur.
3 REPLIES 3
mikecharbel
in reply to: cgentile
Hello
Try this :
-MLEADERSTYLE
-modify
-check "Extend leader to text"
if it solved your issue, then please give kudos and mark my solution as accepted 🙂
cgentile
in reply to: mikecharbel
What version of CAD are you using? The "Extend leader to text" is not available in my settings, also the content is a block, not a text entity.
mikecharbel
I am using autocad 2014 , dont remember if this option is available for other version
can you send ur file so i check it ?
”Boost
