AutoCAD 2010/2011/2012
Active Contributor
snowmannz
Message 1 of 3 (1,334 Views)
Multileader text size not matching style
1334 Views, 2 Replies
02-16-2011 02:59 PM
Hey guys,
Can someone have a look at my file attached and see if you can explain why my multileader text size isn’t matching my text style?
It’s all set up correctly as far as I can tell we used to use text size 2.5 and have decided to drop back to 2. I changed the text style to 2mm. however when I go to do a simple multileader it keeps making the txt size 2.5 and if you look in the properties after the fact it shows it as 25mm
I’m confused as to what’s going on here, it’s pretty simple stuff.
Any help would be much appreciated.
Kind Regards
Corey
Message 2 of 3 (1,332 Views)
Re: Multileader text size not matching style
02-16-2011 03:21 PM in reply to: snowmannz
Edit you mleader style and switch to another text style, OK, then switch back to the KR-Anno Text style.  That should update the text to the correct height.
Active Contributor
snowmannz
Message 3 of 3 (1,325 Views)
02-16-2011 03:39 PM in reply to: ToanDN
Thanks for that, i suspected it was something simple like that.
cheers
corey
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
