AutoCAD 2010/2011/2012
drafter
Message 1 of 3 (349 Views)
Move Command
349 Views, 2 Replies
08-05-2011 09:28 AM
I am having problems moving 3d objects in the vertical direction.  I have no problems moving in the horrizontal direction. Can anyone help?
*Pro
nestly
Message 2 of 3 (342 Views)
Re: Move Command
08-05-2011 10:14 AM in reply to: drafter
It sounds like your UCS is rotated so that the Z-axis is now "vertical" relative to your screen.
Are you working in 2D, or 3D?
If 2D, then type UCS > World at the command line, followed by PLAN > World and AutoCAD will be reset to it's default UCS and PLAN settings.  If you're working in 3D, you'll probably want to spend some time reading about how to manipulate the UCS, but the easiest method is to use the View toolbar, or the View Ribbon panel as they can rotate your UCS to match the view.
GrantsPirate
Message 3 of 3 (340 Views)
Re: Move Command
08-05-2011 10:15 AM in reply to: drafter
Turn the DUCS on, bottom of screen.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
