AutoCAD 2010/2011/2012
roadwayws
Message 1 of 6 (433 Views)
Model Space and Title Blocks
433 Views, 5 Replies
01-04-2012 03:06 AM
Hello it has been quite some time that I have done this. I received a file that the client has that is set up into Model Space and 2 tabs for title Blocks they already have.
After doing the dwg in Model Space how do I get it into the title block Pages.
And as Far as changing the title block I thought there was a file that brought up anything that needed to be changed.
:smileyembarrassed:
Alfred.NESWADBA
Message 2 of 6 (420 Views)
Re: Model Space and Title Blocks
01-04-2012 05:04 AM in reply to: roadwayws
These "tabs" are called "Layout" in AutoCAD, and to get the model-geometry visible on the layouts you have to place at least one viewport plus zoom/pan within the viewport to see the geometry you like to see in the scale you want.
For more info look >>>here<<<.
That's more difficult to answer as we don't see what you have. If it's a block, a XRef, single geometry containing lines and text ... it's differently to handle depending on the geom-type.
The most usual (structured) case is you have an AutoCAD-Block holding attributes, to modify the text-type data you just have to double-click the block.
- alfred -
Alfred NESWADBA
roadwayws
Message 3 of 6 (413 Views)
01-04-2012 05:30 AM in reply to: roadwayws
Thanks I will give it a try later today
roadwayws
Message 4 of 6 (409 Views)
01-04-2012 05:46 AM in reply to: roadwayws
It turns out that the "Model Space has a "Title Block" in it also.
So when I go to move it into the title block Page They over lap and dont line up.
I have to delete one or figure out something because it comes in as a complete
block with the outline of the Model space page.
:smileyembarrassed:
Alfred.NESWADBA
Message 5 of 6 (407 Views)
01-04-2012 05:51 AM in reply to: roadwayws
In well structured drawings the title block has to be placed on the paperspace of the layout, I would delete it from modelspace and _INSERT it in each layout.
- alfred -
Alfred NESWADBA
roadwayws
Message 6 of 6 (403 Views)
01-04-2012 06:17 AM in reply to: roadwayws
Thanks, Its a problem getting DWGs sources from other places.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
