AutoCAD 2010/2011/2012
Active Contributor
StevekBenko
Message 1 of 28 (25,731 Views)
Accepted Solution
Missing Express Tools
25731 Views, 27 Replies
05-20-2011 08:20 AM
I just upgraded from autocad 2011 to 2012 and I'm not sure how to load my express tools. I had this problem before when I upgraded to 2011. The problem I'm having this time is that when I go to the "uninstall/change programs" through windows I only see Autocad Mechanical 2012 (see attached JPG). Anyone have a solution?
*Expert Elite*
Patchy
Message 2 of 28 (25,718 Views)
Re: Missing Express Tools
05-20-2011 08:27 AM in reply to: StevekBenko
Type in CUILOAD, does it show Express?
or type in EXPRESSTOOLS
Active Contributor
StevekBenko
Message 3 of 28 (25,693 Views)
05-20-2011 10:25 AM in reply to: StevekBenko
No, I do not see it listed.
If I open autocad mechanical it shows the express tools. Also, there is a express folder on my hard drive.
Employee
Message 4 of 28 (25,674 Views)
05-20-2011 12:52 PM in reply to: StevekBenko
Hi Steve,
When you install AutoCAD Mechanical you will only see it in Add/Remove programs - there isn't a separate AutoCAD install.  Running AutoCAD 2012 is running mechanical as vanilla AutoCAD.  I'm guessing after installing you ran as Mechanical first  (where you're seeing Express tools), and then as AutoCAD (where the express tools aren't showing up).
Please try this:
Launch as AutoCAD > CUILOAD then click Browse... and browse to/select this file:
C:\Users\<your username>\AppData\Roaming\Autodesk\AutoCAD Mechanical 2012\R18.2\enu\Support\acetmain.cuix
Load and Close and you should see Express Tools.
Chris
Active Contributor
StevekBenko
Message 5 of 28 (25,660 Views)
05-20-2011 01:56 PM in reply to: StevekBenko
THAT DID THE TRICK! Its sooo nice to have tools. thank you!
Active Contributor
StevekBenko
Message 6 of 28 (25,540 Views)
05-25-2011 04:40 AM in reply to: cmiller66
Oops, Im not out of the water yet. The tools have shown up but the commands all return as "unknown command".
*Expert Elite*
Patchy
Message 7 of 28 (25,532 Views)
05-25-2011 06:19 AM in reply to: StevekBenko
DEMANDLOAD is setting at what number?
Active Contributor
StevekBenko
Message 8 of 28 (25,501 Views)
05-25-2011 03:05 PM in reply to: StevekBenko
Setting is 3
Employee
Message 9 of 28 (25,494 Views)
05-25-2011 03:15 PM in reply to: StevekBenko
Hi Steve,
Are the express tools commands recognized when you run as Mechanical or do you get the same thing there?
Chris
Employee
Message 10 of 28 (25,453 Views)
05-26-2011 10:46 AM in reply to: StevekBenko
Hi Steve,
OK, try 2...  Turns out Express Tools are not installed by default for AutoCAD Mechanical so manually loading the cuix file gave you the UI only, not the whole feature.  Sorry about that.
The cleanest way to fix this is to go to your Control Panel > Programs and Features > Uninstall a program then select AutoCAD Mechanical in the list then Uninstall/Change.  When the installer pops up, click Add or Remove Features, check Express Tools and then Update.  For a new install you'd expand the AutoCAD Mechanical 2012 item on the Configure Installation page of the Install wizard and check it so it is included from the start.
Alternately, since you've already loaded the cuix file you can APPLOAD these two FAS files: acettest.fas and acetutil.fas in the Express folder and that should also get you up and running.
Let me know how it goes.
Chris
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
