AutoCAD 2010/2011/2012
Active Member
LegoArchitect
Message 1 of 9 (2,944 Views)
MTEXT is rotated when i try to edit any MTEXT anywhere in modle or paper space.
2944 Views, 8 Replies
07-12-2011 08:34 AM
Why is this happening?
The dwg was fine, then it crashed while changing from modle space to paper space...
When i recovered the dwg, EVERY MTEXT I try to edit becomes rotated vertically and stays that way when i close the edit box...
I do not recall hitting any buttons or making any keystrokes without my knowing...
Is there a way to get my text back to Horizontal and stay that way?
I tried setting the MTEXTFIXED to: 0, 1 & 2.
NONE of these options changed anything.
I NEED to have this fixed. more importantly, i need to know why this is happening sop that i can take steps to prevent this happening in the future...
ANY and ALL help will be greatly appreciated.
I am currently working with the latest CAD available.
Steve
Patchy
Message 2 of 9 (2,919 Views)
Re: MTEXT is rotated when i try to edit any MTEXT anywhere in modle or paper spa
07-12-2011 11:29 AM in reply to: LegoArchitect
Don't use font with @ character in front ( e.g.    @arial.ttf)
Active Member
LegoArchitect
Message 3 of 9 (2,896 Views)
Re: MTEXT is rotated when i try to edit any MTEXT anywhere in model or paper spa
07-13-2011 09:10 AM in reply to: Patchy
Spoiler
Thanks Patchy, that worked perfectly.
Cheers
Steve
GTVic
Message 4 of 9 (2,881 Views)
07-13-2011 10:38 AM in reply to: LegoArchitect
Mark the question as solved...
Active Member
LegoArchitect
Message 5 of 9 (2,823 Views)
09-09-2011 06:26 AM in reply to: Patchy
Hi Patchy,
I really wish my problem were that simple...
in my dwg, there are no texts with the @ symbol in front of it.
If this is not the problem, do you what else it might be?
thanks for the help
Steve
Patchy
Message 6 of 9 (2,815 Views)
09-09-2011 06:37 AM in reply to: LegoArchitect
It is not the text with the @ symbol, it's the FONT style.
Type in STYLE, enter
and see what FONT does it use
or double click the mtext and see the font (see pic)
Active Member
LegoArchitect
Message 7 of 9 (2,807 Views)
09-09-2011 06:54 AM in reply to: Patchy
Wow, that worked perfectly, thank you very much.
Your help is greatly appreciated.
Have a good one!!
Steve
New Member
bwhitley
Message 8 of 9 (1,605 Views)
06-20-2013 06:53 AM in reply to: Patchy
I had the same problem and the @font was the issue.
Thanks for the help
New Member
jeff_mcleod
Message 9 of 9 (164 Views)
06-20-2014 10:44 AM in reply to: bwhitley
I'm not using an @ font, and I'm still getting this. My font is simplex.
When I double-click to edit the text, all is fine until I scroll in or out, then it rotates to an angle.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
