AutoCAD 2010/2011/2012
Active Member
sjmsme
Message 1 of 5 (413 Views)
Lisp Routine fix for CTB files
413 Views, 4 Replies
01-19-2012 10:33 AM
We work with a large number of CTB files, or at least we used to. Trying to streamline the problem. But, as a result of the way things used to be done, we have CTB files for drawings located in the folder of the drawing. Until now, this lisp routine, added to the end of the acad.lsp file, worked just fine for repathing the location autocad looks for the ctb. On my new machine, Windows 7, 64 bit with 2012, it will not work. Any ideas?
here's the lisp routine we use:
(defun C:GC ()
 (setq printerstylesheetdir (getvar "dwgprefix"))
  acadLocation (vl-registry-read (strcat "HKEY_LOCAL_MACHINE\\"
   (vlax-product-key)) "AcadLocation")
 (setenv "PrinterStyleSheetDir" printerstylesheetdir)
(princ)
Here's the error i get now...
Command: GC
no function definition: VLAX-PRODUCT-KEY :error#2*Cancel*
Help!
Thanks!
Shaun
Distinguished Mentor
Moshe-A
Message 2 of 5 (397 Views)
Re: Lisp Routine fix for CTB files
01-19-2012 01:52 PM in reply to: sjmsme
hi,
here is a correction to your lisp function
(defun C:GC ()
		      (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key)) "AcadLocation"))
 (princ)
cheers
Moshe
dgorsman
Message 3 of 5 (389 Views)
01-19-2012 03:05 PM in reply to: sjmsme
Odds are, you are missing a call to (vl-load-com) in your new system.  You should also verify that registry path - it might be different for 64 bit applications.  Also, there is a LISP function (gc) which you might end up conflicting with if not careful with the C: prefix.  Give it a long descriptive name and then use the PGP to shorten it up to GC or whatever works for you.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Active Member
sjmsme
Message 4 of 5 (379 Views)
01-20-2012 03:53 AM in reply to: Moshe-A
Moshe-A,
Thanks but no cigar. Same error.
Shaun
Active Member
sjmsme
Message 5 of 5 (377 Views)
01-20-2012 03:54 AM in reply to: dgorsman
dgorsman,
thanks. I changed the "defun" to getctb and will change the quickkey stroke. Not too sure how to look into my registry on 64 bit.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
