AutoCAD Forum
Link Excel cells to Fields
2 REPLIES 2
plawton5092
9664 Views, 2 Replies
Anyone:
This should be straightforward, but I can't find it after two days of searching.
We are a MEP firm, using AutoCAD 2011 and Excel 2007, and our project is a building with 1000+ rooms.  Each room has specified supply and return airflows that need to show up in text in each of the rooms.  All the airflow values are calculated in a spreadsheet.
My thought is to use fields in the text that shows up in each room, then link each field to a specific cell in Excel, because these values will be evolving over the next year.
Is this a wise approach?  If so, what are the steps?  If not, which way would be better?
Thanks to anyone who can help.
2 REPLIES 2
TerryDotson
in reply to: plawton5092
AutoCAD has no built in mechanism in fields to link to an Excel cell.  If you were to consider third party software take a look at XL2CAD Pro which has a linkage mechanism.  If you need additional automation we can add it.
plawton5092
in reply to: TerryDotson
Thanks Terry.  However, the firms i've worked for have tended to be penny-wise and pound-foolish - unable to bring themselves to spend even $100 on a software solution that would easily pay for itself in the first week.  On their behalf, i apologize.
In other news, however, I did find that Tables will link to Excel ranges, and after a bit of fiddling around with formatting, that seems to work well:
http://docs.autodesk.com/BLDSYS/2011/ENU/filesAUG/WS73099cc142f4875556e08710d8a047f44-7fe6.htm
It remains very manual on the initial set-up, but it can be a big timesaver as the values in Excel evolve 5 or 10 times during the 2-year design process.
Thanks again
”Boost
