Anyone:
This should be straightforward, but I can't find it after two days of searching.
We are a MEP firm, using AutoCAD 2011 and Excel 2007, and our project is a building with 1000+ rooms. Each room has specified supply and return airflows that need to show up in text in each of the rooms. All the airflow values are calculated in a spreadsheet.
My thought is to use fields in the text that shows up in each room, then link each field to a specific cell in Excel, because these values will be evolving over the next year.
Is this a wise approach? If so, what are the steps? If not, which way would be better?
Thanks to anyone who can help.
Solved by plawton5092. Go to Solution.
AutoCAD has no built in mechanism in fields to link to an Excel cell. If you were to consider third party software take a look at XL2CAD Pro which has a linkage mechanism. If you need additional automation we can add it.
Thanks Terry. However, the firms i've worked for have tended to be penny-wise and pound-foolish - unable to bring themselves to spend even $100 on a software solution that would easily pay for itself in the first week. On their behalf, i apologize.
In other news, however, I did find that Tables will link to Excel ranges, and after a bit of fiddling around with formatting, that seems to work well:
http://docs.autodesk.com/BLDSYS/2011/ENU/filesAUG/WS73099cc142f4875556e08710d8a047f44-7fe6.htm
It remains very manual on the initial set-up, but it can be a big timesaver as the values in Excel evolve 5 or 10 times during the 2-year design process.
Thanks again
