To create a linear dimension you have to select two points, then extend line out to show dimension. However, I click to points and move out to press enter and finish it and there i nothing that shows up. After I finish the command it tells me the text height....??? It was working 2 minutes ago just fine. HELP!?!
Can you upload a screenshot with the exact message.
And maybe helpful too would be to know if AutoCAD does that just in one drawing or also in a new drawing (based on an AutoCAD original template).
- alfred -
I have the same problem. In my case, all was working well and then instead of drawing the linear dimension, a vertical line is drawn at the side of the drawing.
I am using AutoCAD LT 2015 - English with Windows 7 Professional 64 bit.
Welcome @forums.autodesk.com!
I'm not sure if it's the same problem, but also in that case please upload a drawing with such a dimension.
Just to make sure: you use a dimensionscale that would make the arrow and text visible. If the dimscale is to small it might be possible that you see only a line because arrows and text is so small that you can't see it.
- alfred -
