AutoCAD 2010/2011/2012
Member
cvriend
Message 1 of 4 (686 Views)
Liking existing viewports to a sheet set
686 Views, 3 Replies
10-11-2012 01:11 PM
I have an existing drawing with numerous viewports. I would like to know if there is a way to link those existing viewports to the set as "sheet views" without having to delete them and re-create them using the normal sheet set process.
I've noticed that each viewport has a variable in its properties display called "link to sheet view" with a yes or no entry, but it doesn't seem changable.
Is this possible, or must I re-create them from scratch?
ArchD
Message 2 of 4 (683 Views)
Re: Liking existing viewports to a sheet set
10-11-2012 01:17 PM in reply to: cvriend
You can't really import viewports into the Sheet Set Manager. The SSM only reads layouts, so it's possible to have muliple layouts per drawing associated with a Sheet Set in the SSM, but not multiple viewports associated as a specific sheet.
You can also create model views using the 'Model View' tab found in the SSM. Basically, when you have a set of layers turned on for one specific viewport, you use the view command from within model space. Once a view in model space is created, you can then insert that model view to a chosen scale into a layout associated with the SSM. Once you insert a model view in this way, it automatically creates a sheet view associated to it (found in the 'Sheet View' tab), as well as automatically drops in a view label.
Archie Dodge
Civil 3D 2013
Windows 7 64-bit
Xeon W3550 3.07 GHz
Nvidia Quadro 4000
12.0 GB RAM
Member
cvriend
Message 3 of 4 (680 Views)
10-11-2012 01:24 PM in reply to: ArchD
I know how to set up the new views within a layout from scratch, but in this case I've already got a layout with multiple viewports within it. What I would like to do is translate those viewports into "sheet views" without having to remake them all.
*Expert Elite*
Message 4 of 4 (658 Views)
10-12-2012 10:06 AM in reply to: cvriend
Great wish list item!  I would go for it.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
