AutoCAD 2010/2011/2012
Active Contributor
jacob.gondek
Message 1 of 4 (292 Views)
Leader lines appearing bold when copied
292 Views, 3 Replies
09-20-2012 06:29 AM
I am using vanilla autocad 2011. installed from the autocad mechanical suite. I keep having a problem when copying blocks, leader lines and text, they sometimes apear bold in paper space. I have used the trick of changing the Z dimension from 0 to 1 and back to 0. My leader lines do not have the ability to do that. How can I keep this from happening. Autocad 2010 never had this isssue. Attached is a capture of the problem, you will see the bold text.
Distinguished Mentor
Moshe-A
Message 2 of 4 (242 Views)
Re: Leader lines appearing bold when copied
09-22-2012 01:53 AM in reply to: jacob.gondek
Jacob,
this is got noting to do with Z dimension (keep all your 2d objects on Z=0)
What's the name of the font file you use?
Does lweight (lwdisplay sysvar) ON? (set it to off)
Moshe
Message 3 of 4 (235 Views)
09-22-2012 05:44 AM in reply to: jacob.gondek
Attach file here that exhibits this behavior.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
pendean
Message 4 of 4 (193 Views)
09-24-2012 06:02 AM in reply to: jacob.gondek
As a test, change the font used to an SHX font, does the problem go away?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
