I'm using AutoCAD LT 2012 on a work computer. I'm having some difficulty with a layout template file. Currently I'm working on transitioning all of our floor plans for various spaces to a new template that we have.
On existing drawings, when I create a new 'layout from template' and select the desired template, the font gets all "messed up". No longer is it the visually pleasing font we have selected for the template, but instead its the ugly acad standard annotative font, not sure what its actually called.
However, when I start out with a new acad file and open up the template in that, it's good as gold.
Why is it that my font "resets itself" when I import the layout template to an existing drawing, but not when I use it in a brand new drawing?
Any help is greatly appreciated. I have over 50 plans to update, and i'd prefer to be able to just import the new layout template to an existing drawing vs. having to Copy and Paste existing drawings into new Acad files that play nicely with my template.
Thank you!!
Solved by hwalker. Go to Solution.
Welcome to the Forums
First things first. Make sure that your 'pleasing' font is installed on ALL your computers that use AutoCAD.
Then try opening your drawings again and see if the problem persists.
Howard Walker
Make sure that the settings for text style you are using are the same for both drawings
eg drawing 1 could have a style called Arial with the font set as Arial.
BUT drawing 2 could have a style called Arial with the font set as Times New Roman.
Howard Walker
