AutoCAD 2010/2011/2012
Member
kmontepare
Message 1 of 9 (3,423 Views)
Jumpy Curser AutoCad 2012
3423 Views, 8 Replies
07-20-2011 01:36 PM
hey i just installed 2012 on my wondows 7 dell computer.
my cursor is so jumpy and i dont even have my snap on. does are there any fixes for this?
please help.
Distinguished Mentor
michael.robertson
Message 2 of 9 (3,388 Views)
Re: Jumpy Curser AutoCad 2012
07-21-2011 04:02 AM in reply to: kmontepare
You might try the AutoCAD 2012 Performance Slowdown Hotfix (32/64 bit)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17013122&linkID=9240698
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Member
kmontepare
Message 3 of 9 (3,380 Views)
07-21-2011 06:48 AM in reply to: michael.robertson
i just tried and that possiby made it a little worse. Thank you for the sugestion. Any one else i will try anything. this is so aggrovating.
michael.robertson
Message 4 of 9 (3,372 Views)
07-21-2011 06:54 AM in reply to: kmontepare
Sorry to hear that. Just a shot in the dark. Using 3D config, sometimes just disabling and re-enabling Hardware acceleration has helped.
What type of mouse are you using? I don't know if I've seen this in Autocad but certain version of Microsoft's Intellimouse software has caused problems for me (an others) in MicroStation & Photoshop (it tries to continually update a snap shot of the screen). We had problems with versions around 6.2 if I remember right.
Mike Robertson
Member
kmontepare
Message 5 of 9 (3,368 Views)
07-21-2011 07:13 AM in reply to: michael.robertson
a logitech mouse- i have had for like 2 years.
yeah i have no idea what is causeing this. I am not even doing anything complicated just floor plans sypmle. not x-refs. this is basic use here.
thanks for your help. i will get with my IT department and see what they say.
Member
kmontepare
Message 6 of 9 (3,363 Views)
07-21-2011 07:56 AM in reply to: kmontepare
here was what i did to solve it. - it was my graphics card. Thank you for your help!!!
There are a couple of settings that can be changed that generally get rid of this.
In the tray settings disable Selection Cycling (if in AutoCAD 2011), Quick Properties and Dynamic Input. If this doesn't improve the situation then go to Tools>Options (or type in Options at the command line) and on the Display tab uncheck the ‘Show rollover ToolTips’ option. Also try the Selection tab and uncheck 'When no command is active' under Selection Preview.
It's always a good idea to make sure you're using a graphics card driver that has been tested and recommended by Autodesk for the AutoCAD or AutoCAD based product.  To verify what driver you should be using use the 3DCONFIG command. The View Tune log will indicate what version is installed. Verify if this is the recommended one at:
http://www.autodesk.com/autocad-graphicscard
While you're in 3DCONFIG go to Manual Tune and make sure that 'Enable hardware acceleration' is selected.
With all these changes you should notice an improvement and your mouse will no longer "snap" and cause a delay.
Active Member
Cad_enthusiast
Message 7 of 9 (1,962 Views)
09-04-2012 09:43 AM in reply to: kmontepare
one of my coworker has the same problem with jumpy curser even snap is OFF.   However we notice that it only happens in certain files and if he copied everything from the old file to a new templete, the problem is gone. If the same file is opened by another user, the problem is gone.
Any idea what would have caused this jumpy curser other than the graphic card? Thanks!
Alfred.NESWADBA
Message 8 of 9 (1,958 Views)
09-04-2012 10:03 AM in reply to: Cad_enthusiast
If you think it's drawing-depending that upload one of these "defect" drawings, that would help to identify the problem.
- alfred -
Alfred NESWADBA
Active Member
Cad_enthusiast
Message 9 of 9 (1,950 Views)
09-04-2012 05:22 PM in reply to: Alfred.NESWADBA
Is there anywhere I can email you the file instead of uploading it to the public?
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
