AutoCAD 2010/2011/2012
Distinguished Contributor
Message 1 of 3 (135 Views)
JPGs spontaneously disappear
135 Views, 2 Replies
03-20-2012 09:16 AM
It must be Raster Image Day on the discussion groups...
ACAD Architecture installed as 32-bit on Win 7 64 bit machines w 12 gig ram. My users are using that g.d. CAP studio program, hence the 32 bit install.  SP1 is installed as are hotfixes for Ribbon and Dimension issues.
Here's what's happening: most of the time we have no issues with raster images attached to the files.  However, every once and a while one of the images decides to not show up.  In XREF manager, everythings fine - the paths to raster images are correct (shared network path).  The files are loaded, the insertion layers are on. You can close out of AutoCAD and come back in - sometimes the image pops back in.
Even though these are plot settings, I have RASTERPERCENT set to 80, and Raster Threshold set to 120 (although the size of most of these images is around 100k)
Anyone know if this is a known issue with 32 bit installs of ACAD?
THANKS!
LOU
pendean
Message 2 of 3 (119 Views)
Re: JPGs spontaneously disappear
03-20-2012 11:23 AM in reply to: lholland
Did you eliminate the more common errors?
- The image resides on a layer that is turned off/frozen.
- The image is off: turn on the imageframe, select it and turn SHOW IMAGE back on using PROPERTIES.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Message 3 of 3 (114 Views)
03-20-2012 12:17 PM in reply to: pendean
Thanks for the input.
After doing some testing, I've concluded that the problem is the "unnatural" install of Autocad as a 32-bit app on a 64 bit system.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
