AutoCAD 2010/2011/2012
New Member
Laura1171
Message 1 of 5 (272 Views)
Issue with dragging nodes & it dragging other objects attached.
272 Views, 4 Replies
03-09-2013 07:43 AM
When I click on an object and highlight the nodes. Then when I click on a node to stretch or move the object it is taking everything else at that intersection point with it.How do I avoid this please. Any suggestions.
Alfred.NESWADBA
Message 2 of 5 (267 Views)
Re: Issue with dragging nodes & it dragging other objects attached.
03-09-2013 07:49 AM in reply to: Laura1171
The GRIP-STRETCH only stretches the selected objects. If there are other objects "under" that one grip you used to stretch it away there should not be stretched any non-selected object.
The only exception I can imagine is that you are speaking about a polyline that crosses itself and you grip the poly at a coordinate where are more than one polyline-vertex. In that case you would have to use command _PEDIT as this is the only chance (I know) to specify the vertex-number without picking it's coordinate.
- alfred -
Alfred NESWADBA
hmsilva
Message 3 of 5 (260 Views)
03-09-2013 08:17 AM in reply to: Laura1171
Laura, your description makes me think if there is a "constraints" problem, if that, under Parametric menu, Delete Constraints and select the objets to remove constraints, then try to  stretch the object again.
hope that helps
Henrique
New Member
Laura1171
Message 4 of 5 (249 Views)
03-09-2013 10:04 AM in reply to: Laura1171
Henrique,
Thank you for your reply. That solved the problem.
Thank you,
Laura.
hmsilva
Message 5 of 5 (245 Views)
03-09-2013 10:15 AM in reply to: Laura1171
You're welcome, Laura
glad I could help
Henrique
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
