AutoCAD 2010/2011/2012
New Member
sivashivam
Message 11 of 15 (1,391 Views)
Re: Installation aborted, Result=193
04-27-2011 02:17 AM in reply to: jdonleyco
Install Autocad directly from DVD, not from hardisk.
I installed in xp machine successfully.
New Member
KendraKuzma5522
Message 12 of 15 (1,169 Views)
10-13-2011 08:46 PM in reply to: alainr345
It is October 2011 and still no fix for this?  I have 12 hours invested so far and still  get error -Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) failed. I have been on the phone with my distributor who wants me to download the install and not use the DVD. With my connection it will take 12 hours and fail after about 6 hours. I have deleted and reinstalled every version of VC++ I can find and then run install and it still fails. I have uninstalled VC++ and let it load from DVD and still fails. I am seriously considering not re upping with ACAD. I cant afford the delays every year.
New Member
shastry.sushruth
Message 13 of 15 (1,100 Views)
worked!
12-16-2011 09:31 PM in reply to: jdonleyco
This worked for me :
Solution : Remove the existing copy of the VCredist that u have which actually has a conflict with the installer.
The story :
Guys.. My error was this :
Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\sushruth\AppData\Local\Temp\vcredist_x86_2010.log
2011/12/17:10:46:55	sushruth	SPC	Install	Microsoft Visual C++ 2010 Redistributable (x86)	Failed	Installation aborted, Result=1603
 So i went to that location
 And tried to execute it myself. I got this error :
A newer version of this package is already installed on your computer
So what i did was, i removed the existing copy and let the installer install the copy that came with it. now it works! I signed up just to share this info :smileyhappy:
New Member
marcflu
Message 14 of 15 (833 Views)
08-29-2012 05:10 AM in reply to: jdonleyco
This works:
Change the directory of the install !!
I made it Autodesk_"name of program"
and not just Autodesk
This seemed to make it work. I have 3DS Max Design 2012 installed and wanted to install the 2013 version.
It works now..
New Member
matthewfuller
Message 15 of 15 (575 Views)
Re: worked!
02-12-2013 06:40 PM in reply to: shastry.sushruth
thankyou! this also worked for me too.
I tried updating the files via microsoft and installing every virsion from 2005-2012 which did not work, when i removed them all it installed.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
