(ACAD LT 2012)
Hello!
I have the LAYER CONTROL TOOLBAR Up... the thing that shows Layer Properties Manager...Layer ON/OFF / Freeze/Thaw Layer Name etc....
PROBLEM:
When I click on an object, it does not show me what layer it is on. And I can't use it to change the layer of the object either. It's totally inactive.
QUESTION:
Has anybody else had this issue, or come across how this can BECOME ACTIVE?
Thanks.
-M-
Solved by nestly2. Go to Solution.
lol -- wait, you were joking right?
I just now realized that I was in the wrong part of the forums.
I'm glad this worked for ACAD LT.
Thanks for the solution -- it worked. Although now I'm wondering what would have caused it to go to 0 in the first place.
-M-
[edited] What a gyp... i can no longer edit my original post to provide solution. I know that's a button that takes me TO the solution, but I like to Edit the Original and just put it right there under the question in Bold or RED. Oh well....
SOLUTION:(as provided by nestly2) Change PICKFIRST to 1
@-m- wrote:lol -- wait, you were joking right?
Actually .... no. Noun/verb Selection is the "non-technical description" used in OPTIONS for the PICKFIRST variable.
Noun/verb, means you can select the object(s) (noun) before choosing the action (verb), otherwise you must choose the command first, then select the objects, which obviously doesn't work with some AutoCAD features. Note: The Ribbon Layer Control doesn't adhere to Noun/Verb selection, it works on selected object(s) either way.
Anyway, glad you got it sorted out, and yeah, there is a time limit for editing posts... I've been burned by that too.
Thank you Very Much. . I also faced the same problem. Now i got solution
