AutoCAD 2010/2011/2012
Member
Message 1 of 7 (6,796 Views)
Accepted Solution
Importing .sat/.igs/.step files into AutoCAD 2011 Educational
6796 Views, 6 Replies
01-14-2013 12:50 PM
I am trying to import .sat files into an educational version of autoCAD 2011. I am using the import command and selecting the .sat format selecting the file and then I am getting "Unable to read the ACIS file E:\001904 GS PM_2.SAT"....any suggestions?
*Expert Elite*
Alfred.NESWADBA
Message 2 of 7 (6,787 Views)
Re: Importing .sat/.igs/.step files into AutoCAD 2011 Educational
01-14-2013 02:21 PM in reply to: danielsm
what version does the SAT-file have?
Reading the help brought my to my first tip: AutoCAD 2011 does support SAT-files versions up to 7 (>>>details<<<).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
Message 3 of 7 (6,758 Views)
01-15-2013 04:44 AM in reply to: danielsm
as indicated - Autodesk products will open ACIS (*.sat) files up to v7.
For *.igs or *.step or *.stp you would need a later version of AutoCAD or you could use the FREE
Inventor Fusion http://labs.autodesk.com
You can check the version of an ACIS (*.sat) file by opening in Notepad and check the first or second line.
Search for download of Hoops ACIS Viewer if you need to convert from a later version of ACIS down to v7.
The menu location in Hoops to convert down to v7 is not where you might expect it to be - so look around.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Member
Message 4 of 7 (6,741 Views)
01-15-2013 09:58 AM in reply to: Alfred.NESWADBA
I am actually not sure what version .sat file it is......it was given to me by a third party and checking properties gives me little to no info.....the file is attached....any ideas?....Thank you for the help....actually this forum will not let me upload the .sat file.......
Member
Message 5 of 7 (6,740 Views)
01-15-2013 09:59 AM in reply to: JDMather
wow ok didnt read this before replying, thanks for the help!!
Member
Message 6 of 7 (6,735 Views)
01-15-2013 10:05 AM in reply to: JDMather
So I opened the .sat file in notepad (see attache jpg) and it appears that it is version 19?....however in AutoCAD when going import>acis> then selecting file I still get....."import Unable to read the ACIS file E:\001904 GS PM_2.SAT".....???
*Expert Elite*
Message 7 of 7 (6,714 Views)
01-16-2013 03:41 AM in reply to: danielsm
danielsm wrote:
... I still get....."import Unable to read the ACIS file E:\001904 GS PM_2.SAT".....???
You must have missed the point that Autodesk products only read up to v7 ACIS, so of course AutoCAD is not going to read a v19 ACIS file.
You will need to use something like Hoops ACIS Viewer (search Google) to convert down or ask the source to set the save Option to v7 or ask the source for a STEP (*.stp) file or *.dwg.
If you attach the file here - I will convert it for you.
First you must right click on the filename and select Send to Compressed (zipped) Folder, and then attach the resulting *.zip file here.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
