AutoCAD Forum
Importing Points
12 REPLIES 12
Message 1 of 13
bwahaha28
638 Views, 12 Replies
Importing Points
Can anyone help me import points (multiple) with label and codes? Im using cad 2012. Thanks!
12 REPLIES 12
Message 2 of 13
pendean
in reply to: bwahaha28
Import from what?
Message 3 of 13
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
+1 with Pendean
You are speaking about :
- CSV files like  X,Y,Z,Label,Code  or  X;Y;Z;Label;Code
- XLS files with the same Info
- or what ?
The Health, Happy New Yaer, Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 13
bwahaha28
I want to import points from .csv (E,N,elev,D). Is this possible? thanks! 🙂
Message 5 of 13
Jay_B
This should topic be posted over in in the Civil 3D General Forum
The Point and Survey Tutorials will help get you started on the right track with setting up the Points & Survey features properly in Civil 3D.
If that Point File Format doesn't exist you can create a custom Point File Format. Help
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 6 of 13
bwahaha28
Uhm... Im not using cad civil 3d.. Im using the simple autocad 2012.. Im wondering if it is possbile to import points from .csv.. If not how can i input my points penzd to autocad 2012 (NOT civil3d)? Is it possible that it will also diplay point label?
Message 7 of 13
Jay_B
Sorry to have made the Civil 3d assumption. Since you asked a closely related question in the civil 3d forum it seemed they may have been related.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Working-with-Description-Keys/td-p/4758793
IMHO, if I had access to AutoCad and Civil 3d I would choose Civil 3d to import points and create the point table.
C3D 2018.1
C3D 2016 SP4
Message 8 of 13
bwahaha28
Yep,its a lot easier using civil 3d..., but i only have simple cad 2012 in my pc. Sometimes i have access to civil3d if my officemate with civil3d is not using his pc. I want to maximize my 2012 cad.
Message 9 of 13
Jay_B
There are no built in commands which will import and label point #'s, descriptions, coordinates and elevations found in basic AutoCad.
A third party or some customization is required.
C3D 2018.1
C3D 2016 SP4
Message 10 of 13
pendean
... Or using your colleagues Civil3d station.
Message 11 of 13
Alfred.NESWADBA
It's easier if you have an app doing the import, but you can do this using Excel too.
Open the file in Excel, use formulas to create a new column in the XLS that you can then use with copy+paste to the commandline in AutoCAD.
You need also a block holding an attribute for "D" (I guess it's "description", but wondering why there is no pointnumber in the CSV).
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 12 of 13
TerryDotson
... i only have simple cad 2012 in my pc.
Obtain a 30-day full working evaluation of MapWorks Points and import your points.  It's Point File Convert Text will accept any ascii file, you simply tell it the separator and field order.
Message 13 of 13
braudpat
in reply to: TerryDotson
Hello from France
I am using a nice VLisp routine from Gilles (gile) to import this kind of file ... MAT,X,Y,Z
It works on any AutoCAD 201x (even on ACAD Architecture, MEP, MAP, CIVIL, etc)
Input file has to be a 4 fields/columns text file with separator like : <space> or , or ;
You must have a Block READY with 2 attributs :  MAT  and  ALT
MAT (1st attribute) can be anything but it is in fact the first column/field of the input file
ALT (2nd attribute) will be automatically filled with the Z column/field (ALT = Altitude)
Of course the Block is inserted a the X Y Z coords of the input file ...
I have made "minimum" translation of this routine : TOPO2
And I have retested this US/English version of TOPO2 on my MAP 2014 and MAP 2011, so ...
Here a test input file :
MAT001,11,12,1
MAT002,21,22,2
MAT003,31,32,3
In the ZIP file, you will find : the Block DWG, the TOPO2 routine, the test input file ...
You can insert FIRST somewhere the Block "BLOC_MAT_ALT" in your DWG
then TOPO2
then choose the Block Name or select it or Browse
then OK
then you browse to find your input file
the choose the separator
and then let's go ...
You can change the visibility of the ALT attribute if you don't want to see it !?
Bye, Pat (Thks to Gilles)
Patrice BRAUD
”Boost
