AutoCAD 2010/2011/2012
Member
AdrianWelsh
Message 1 of 9 (15,916 Views)
Importing ESRI shapefile (shp) into AutoCAD 2011
15916 Views, 8 Replies
01-03-2012 07:42 AM
Hi, I'm new (again) to using AutoCAD and am a GIS user.  I just wanted to know if there was a way to import an ESRI shapefile (.shp extension) into AutoCAD 2011.  This is the only version I have and don't really have any extensions with it.  Can I do this or do I need different software?
thanks!
Message 2 of 9 (15,895 Views)
Re: Importing ESRI shapefile (shp) into AutoCAD 2011
01-03-2012 09:58 AM in reply to: AdrianWelsh
i beleive you can download ESRi for Autocad from Esri site for free.
Message 3 of 9 (15,891 Views)
01-03-2012 10:04 AM in reply to: vakhtang
lol ArcGIS for autocad of course :smileyhappy:
Member
AdrianWelsh
Message 4 of 9 (15,885 Views)
01-03-2012 10:07 AM in reply to: vakhtang
Thanks for the reply.  I have installed the ArcGIS for AutoCAD extension but I do not see where I can bring in a shapefile.  I might be able to bring in geodatabase files (it says feature classes) but it has no option for bringing in a shapefile.
I am wondering if my version of AutoCAD allows this sort of thing or not.  I was browsing the forums and it seems that AutoCAD Civil 3D and other versions/extensions can do that but maybe not just regular AutoCAD 2011?
thanks!
Message 5 of 9 (15,880 Views)
01-03-2012 10:11 AM in reply to: AdrianWelsh
that i cannot tell you :smileyhappy: i only know i have ArcGis installed on 2009 . Check tutorials maybe?
Valued Mentor
TerryDotson
Message 6 of 9 (15,855 Views)
01-03-2012 02:37 PM in reply to: AdrianWelsh
Plain AutoCAD won't import Shapefiles, but AutoCAD Map/Civil3D will.  I'm not aware of any ESRI plug-in for this.
If you were to consider third party add-ons, take a look at MapWorks Base which will import the contents of ESRI Shapefiles, including the DBF contents as extended data.
Member
AdrianWelsh
Message 7 of 9 (15,845 Views)
01-03-2012 04:52 PM in reply to: TerryDotson
thanks for the info!
New Member
Message 8 of 9 (8,173 Views)
04-28-2013 09:12 PM in reply to: AdrianWelsh
Hi we can only import esri shapes in autocad map/autodesk map without any extensions or plug in:mansurprised:...You cannot import in any version of autocad...:smileyhappy:
New Member
Message 9 of 9 (8,162 Views)
04-28-2013 11:52 PM in reply to: Jeshi
gud one
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
