AutoCAD 2010/2011/2012
Valued Contributor
Message 1 of 12 (2,840 Views)
IMAGEFRAME AND OLEFRAME equal to 0 still not turning off frame
2840 Views, 11 Replies
07-13-2012 06:10 AM
I have a logo that is a jpg file Xref'd into a title block xref file. In my sheet files IMAGEFRAME and OLEFRAME are set to 0. They are set that way in the Title Block file as well. I still have some sheet files with these system variables set to 0 that still print the border around the logo.
Any help with this issue would be greatly appreciated !
Patchy
Message 2 of 12 (2,839 Views)
Re: IMAGEFRAME AND OLEFRAME equal to 0 still not turning off frame
07-13-2012 06:13 AM in reply to: aturner77
Try FRAME
pendean
Message 3 of 12 (2,791 Views)
07-16-2012 05:38 AM in reply to: aturner77
for some reason, in some of my files, you have to be in MODELSPACE to turn those variables off before they work on content in paperspace. See if that's your issue with your files as well.
Not sure why it only happens to some, but that's the fix for them here.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
Message 4 of 12 (2,690 Views)
09-19-2012 11:50 AM in reply to: pendean
I am experiencing this same issue.  When plotting to PDF the image frame still partially plots even though I have set FRAME to 0.  Are there any settings for this strictly related to plotting to PDF?  I am plotting straight from MODELSPACE.
pendean
Message 5 of 12 (2,676 Views)
09-20-2012 05:51 AM in reply to: jeffgray
frame partially plots? has in it may be part of the image?
ArchD
Message 6 of 12 (2,670 Views)
09-20-2012 10:44 AM in reply to: aturner77
Toggle TFRAMES off?
I usually set my IMAGEFRAME to 2. This allows the frame to be seen and selected, but wont plot.
Archie Dodge
Civil 3D 2013
Windows 7 64-bit
Xeon W3550 3.07 GHz
Nvidia Quadro 4000
12.0 GB RAM
Member
Message 7 of 12 (2,656 Views)
09-21-2012 07:16 AM in reply to: ArchD
I tried that. No help. I did read somewhere that particular images could have a problem plotting without image frames. I tried converting it to png and jpeg using Raster Design. Still doesn't plot correctly. It only shows up on one or two sides of the image each time, and is very faint for the most part. Any other ideas would be greatly appreciated.
Member
Message 8 of 12 (2,656 Views)
09-21-2012 07:17 AM in reply to: pendean
No, I don't think it's part of the image because even when I clip that part off the clipping boundary partially plots.
Active Contributor
Message 9 of 12 (2,643 Views)
09-21-2012 02:15 PM in reply to: jeffgray
I often have to turn my IMAGEFRAME = 0 (on)(even though they are already on), then IMAGEFRAME =1 (off).
Earl
New Member
Message 10 of 12 (2,329 Views)
02-13-2013 09:21 AM in reply to: Earl.Morrill
Turning them on (setting IMAGEFRAME to 1) (even though they were already on) and turning them off again (turning IMAGEFRAME to 0) worked for me.  Thx!
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
