Hi, I've looked a couple of time sin the past for a solution to this but get nowhere.
Whenever I click on the 'Hyperlink' button, it lets me select an object, but then it hangs AutoCAD. I just get the spinning circle thing, and I have to crash AutoCAD using the task manager.
What's even better is that I just asked a co-worker to try and his works fine - it lets him add a link, it even went to the link (the stuff of legend).
Since our machine are set up almost identical, what's going on? Is there some little setting somewhere that's been switched?
Any help would be great - thanks.
Win 7 Civil 3D 2012, if that helps.
Just wait a little longer, this is a know issue on large folders - see:
http://www.cadforum.cz/cadforum_en/hyperlink-is-very-slow-hangs-on-the-first-run-tip6344
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
