AutoCAD Forum
How to use -Insert
4 REPLIES 4
Jason-Cad-123
517 Views, 4 Replies
How to use -Insert
I am trying to write a script and I need some help.
I need to inset a block using -insert. Then i need to specify a file path and then the block name.
File path: svr\access\test\revision
Block name
P2.scr
4 REPLIES 4
pendean
in reply to: Jason-Cad-123
What do you type at the command line after you type -INSERT? Scripts are just that, what you can type and get to work at the commandline.
doni49
As Dean said, a script contains the same thing you'd enter at the command line.  The simplest way to get what you need is to open notepad and acad.  Then do the first one manually and start entering the info into acad -- start with -insert.  Then everytime you press enter, type the same exact thing in notepad (every time you hit enter in acad, that belongs on a new line in notepad).  Then after you're done with the first one, you should be able to save and use your script file.
After that, if you still have issues, come back and ask.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
braudpat
in reply to: doni49
Hello
You have written ---> File path: svr\access\test\revision
It could be --> File path: \\svr\access\test\revision
if \\srv is the hostname of your Server !?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
-insert C:/svr/access/test/revision/p2 0,0 1 1 0 Assumptions: the file is on your C drive, if not use the correct one. The block is named P2, if not substitute for the correct one. Insertion point is 0,0, scale of X and Y is 1, rotation is 0.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
”Boost
