I am trying to make a 3-D model from a 2-D sketch I made. I have only worked in 2-D so I'm not sure on how to do that. I have a sketch of heart with two names on the inside. I want to make the heart solid while leaving the inside of the letters open so you can see through the letters. Attached is the sketch I made. Any advice is appreciated.
Thank you.
Solved by Patchy. Go to Solution.
You can use command PRESSPULL and pick between the letters and the heart.
or use EXTRUDE command, after that use SUBTRACT command.
I tried that but all I was able to do was raise the letters. I couldn't raise the heart or make them solid.
Because the heart shape isn't slosed (joined together)
You can use command REGION, select the heart, then extrude all entities in 1 shot.
Did you use Presspull (not Extrude)?
Here is a short video that will show you how to make 3D Text. You can then use this text to subtract from the other 3D objects.
http://screencast.com/t/qdNZaR0aVsAf
I would use this one for free
