AutoCAD 2010/2011/2012
shanower
Message 1 of 38 (40,245 Views)
How to reduce file size in AutoCAD?
40245 Views, 37 Replies
07-03-2010 06:45 AM
Can anybody tell me how I can reduce the file size in AUtoCAD 2011, please?
Shanower
Valued Mentor
wengle
Message 2 of 38 (40,228 Views)
Re: How to reduce file size in AutoCAD?
07-03-2010 09:11 AM in reply to: shanower
Reduce what file size? You can't reduce autocad's files without destroying it altogether. Do you mean to reduce file sizes of dwgs? Be more specific.
Active Member
kia9878
Message 3 of 38 (40,158 Views)
07-05-2010 11:17 AM in reply to: shanower
purge your drawings, and set ISAVEPERCENT to "0", and that should do the trick!
also, deleting all of your *.bak files will save disk space, assuming you back-up your server on a regular basis
*Pro
Modman_4
Message 4 of 38 (40,121 Views)
07-06-2010 07:10 AM in reply to: kia9878
You could try writing your entire drawing off as a block, open the new block using RECOVER, then purge it and save over top of your old drawing...
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
shanower
Message 5 of 38 (40,091 Views)
07-06-2010 11:20 AM in reply to: shanower
Thank you very much for replying. Yes I want to reduce size of dwg file. Does anybody have any good solution?
Shanower
Message 6 of 38 (40,085 Views)
07-06-2010 03:21 PM in reply to: Modman_4
except that anything on paperspace will be gone.
*Pro
Modman_4
Message 7 of 38 (40,064 Views)
07-07-2010 06:44 AM in reply to: ToanDN
"except that anything on paperspace will be gone."
Not true when you write off the entire drawing as a block. What you do end up having to reinstate are your plot parameters, using the Page Setup Manager.
Message 8 of 38 (40,048 Views)
07-07-2010 10:34 AM in reply to: shanower
Yup.  Forgot about that "entire drawing" option.  I was thinking about select All objects.
Valued Contributor
tfisch86
Message 9 of 38 (40,033 Views)
07-07-2010 12:42 PM in reply to: ToanDN
Purge (PU)
type that in command line, in the dialouge box, click "Purge All". You may have to click this a few times, keep doing it until it is unhighlighted and you cannot click it anymore.
There is also a "purge" for files that have been created in another program, such as Revit, that allows you to purge the "garbage" that comes along with them.. I forget the command, but the sub command I remember is "R"
*Pro
Modman_4
Message 10 of 38 (39,965 Views)
07-09-2010 09:09 AM in reply to: tfisch86
You may be thinking of Regapps...
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
