AutoCAD 2010/2011/2012
JamaL9722060
Message 1 of 4 (2,331 Views)
Accepted Solution
How to plot (draw) the xy data saved in a CSV file?
2331 Views, 3 Replies
02-25-2012 03:35 PM
I’m not sure if there is an enhanced workflow to plot the xy coordinates saved in an CSV file in the AutoCAD 2012.
I found the approach below in the web
1.Open the Excel file.
2. Save it as a .CSV file (comma separated values).
3. Open the .CSV file in notepad, add two lines at the top:
._multiple
._point
4. Then save this file with a .SCR file extension.
5. In AutoCAD run the ._Script command, and pick the .SCR file above.
Is there a better way?
Thank you in advance,
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 4 (2,318 Views)
Re: How to plot (draw) the xy data saved in a CSV file?
02-26-2012 02:11 AM in reply to: JamaL9722060
the approach doing this with script is OK.
One additional option would be to create a new column in Excel (using formulas) that contains X and Y (and optional Z) values separated with "," (and decimal-character as point), so the column looks like this
10.23,400.5
20.45,401.0
23.10,402.5
21.98,403.0
And now you can mark the fields in this column in Excel ==> <Ctrl>-<C> to bring them to the copy-buffer.
Change the focus to AutoCAD ... to the command-line, type in (as you already mentioned)
_MULTIPLE<ENTER>
_POINT<ENTER>
<Ctrl>-<V>
that pastes the coordinates directly into the command-line and you don't need to create a script-file.
Just another way, same result :smileywink:
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
JamaL9722060
Message 3 of 4 (2,304 Views)
02-26-2012 01:13 PM in reply to: Alfred.NESWADBA
Perfect Alfred. This is a quite satisfactory workflow and important contribution. Brilliant
Many thanks
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
JamaL9722060
Message 4 of 4 (2,281 Views)
02-27-2012 01:11 PM in reply to: Alfred.NESWADBA
Hi Alfred,
Could you please have a look on the link of the thread below, it is quite relevant to this thread.
http://forums.autodesk.com/t5/AutoCAD-2012/Points-Labeling/td-p/3348259
best
Jamal
Firefox 20.0,
Kaspersky 2013.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
