AutoCAD 2010/2011/2012
susc2001
Message 1 of 10 (17,925 Views)
Accepted Solution
How to draw a thick line
17925 Views, 9 Replies
08-05-2010 08:34 PM
I'm currently using CAD 2010 and I want to draw a think line. I draw a polyline and than I open up the properties box and give it a thickness but the line gets thick in a 3 dimensional manner. I need the line to show thinkness but in 2 dimensional.
BernardMadoff
Message 2 of 10 (17,893 Views)
Re: How to draw a thick line
08-06-2010 01:07 AM in reply to: susc2001
just use lineweights and if you want to see the lineweights on your screen toggle on the hide / show lineweight icon @ the bottom of your screen.....but note AutoCAD does a pretty crap job of displaying lineweights on screen.
they will print ok though
*Expert Elite*
M_Hensley
Message 3 of 10 (17,877 Views)
08-06-2010 03:32 AM in reply to: susc2001
Use PEDIT command, select your polyline and use W option to give it a width.
New Member
zubair-o
Message 4 of 10 (17,784 Views)
08-09-2010 04:37 AM in reply to: susc2001
plz anwser me?
Valued Mentor
TrevN
Message 5 of 10 (17,770 Views)
08-09-2010 06:51 AM in reply to: zubair-o
Adding to the previous answers already given, change it's global width in the properties dialogue box.
susc2001
Message 6 of 10 (17,722 Views)
08-11-2010 12:51 AM in reply to: susc2001
Thank you for your suggestion. Your method works and also changing the global factor in the properties box does the same thing.
susc2001
Message 7 of 10 (17,720 Views)
08-11-2010 12:52 AM in reply to: TrevN
Thank you for your suggestion. It worked and also using command "pedit" and changing the width factor does the same thing.
susc2001
Message 8 of 10 (17,717 Views)
08-11-2010 12:55 AM in reply to: BernardMadoff
Thanks for your suggestion.
Member
a01175228
Message 9 of 10 (4,035 Views)
03-17-2014 02:54 PM in reply to: susc2001
Which is the code to make a think line in the Model View?
I want to start doing the ticker line,not to do it and later by PEDIT changing it to thinker.
Thank you
*Expert Elite*
Kent1Cooper
Message 10 of 10 (4,003 Views)
03-18-2014 06:25 AM in reply to: a01175228
You can either start a PLINE command and, after giving it a start point, use the Width option, or you can set the PLINEWID System Variable to the desired width before starting PLINE.
Kent Cooper
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
