AutoCAD 2010/2011/2012
New Member
kadyk83
Message 1 of 5 (6,427 Views)
Accepted Solution
How to delete an object or a line
6427 Views, 4 Replies
02-13-2011 12:21 PM
1.       AutoCAD 2011, new user & new install. I’m going throught the tutorials and have lost ability to repeat past ability to do tasks. One being to highlight an object and then delete using the Delete key. Second example being lost is to left click a drawn line and then to hit delete. Is this a setup problem?
Valued Mentor
wengle
Message 2 of 5 (6,415 Views)
Re: How to delete an object or a line
02-13-2011 01:21 PM in reply to: kadyk83
Why use delete key? Bad habit. Press E (erase), right click and then pick object and right click.
This also pertains to second item.
New Member
kadyk83
Message 3 of 5 (6,409 Views)
02-13-2011 01:43 PM in reply to: wengle
yes, that is good. although, there might be times that I would want to be able to hightlight an object and delete that portion of it. I thought it might be in the settings and something might be amiss.... thanks. I like this "e" and delete
*Expert Elite*
mathewk
Message 4 of 5 (6,392 Views)
02-13-2011 05:47 PM in reply to: kadyk83
Using the delete key is not a bad habit at all.  I'm betting the value for PICKFIRST is set to 0.  Type PICKFIRST and set the value to 1 and try again.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
New Member
ajay.ces
Message 5 of 5 (5,613 Views)
06-22-2012 10:52 PM in reply to: kadyk83
Thanks was really Helpfull!!!!:smileyhappy:
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
