I get this message when I open a drawing: 3 hatches'lines were not generated because their density exeeded available memory. But I didn't insert any hatched lines into my drawing... Strange!
Solved by Alfred.NESWADBA. Go to Solution.
Thaw all layers and turn them on, then try command _QSELECT, choose objecttype "Hatch" and operator "Select All" ... are there now objects gripped (at least in property window shown as selected)?
If not in modelspace it might also be necessary to do that for every layout.
It might also be possible, that hatches are placed in block-definitions, quite tricky then to find them, but possible.
If all fails ... upload the drawing.
- alfred -
>> Nah, that doesn't work... Here's the file.
When I start _QSELECT, object type "HATCH", operator "Select All" ... I get 3 hatches selected.
What does not work for you?
- alfred -
hi!
You have 3 hatches in Your drawing - https://dl.dropboxusercontent.com/u/401581/4%20TV%20hatch.png
In drawing I marked region where they are - https://dl.dropboxusercontent.com/u/401581/4%20TV-kast.dwg
Regards
Juris
Ok, sorry guys. I didn't see them first. As soon as I moved them I could see them... Stupid me
In fact, I never used that command before. It lookt pretty usefull for some other thing also!
That's the fun of ACAD, you learn every day! Keeps you awake 🙂
Thx for the help!
