AutoCAD 2010/2011/2012
Active Member
mattsears18
Message 1 of 3 (1,790 Views)
How can I calculate cut and fill?
1790 Views, 2 Replies
07-14-2011 06:17 PM
I've used autocad for a while, but I've never created surfaces or anything. Right now I'm using autocad 2011, but I can get civil 3D if need be.
I have a file with existing contours and proposed contours. How can I make 3d surfaces and calculate the cut and fill?
Many thanks!
Member
engqld
Message 2 of 3 (1,781 Views)
Re: How can I calculate cut and fill?
07-14-2011 08:58 PM in reply to: mattsears18
The way I would do this would be by creating the two surfaces in AutoCAD Civil 3D both being a Tin Surface with the appropriate elevations as per the countour heights. Once you have both surfaces you can then create a Tin volume which you set a base and comparison surfaces once this is created under go to surface properties - statistics - volume this will give you a cut fill and net volume.
Hope this helps
Message 3 of 3 (1,763 Views)
07-15-2011 07:09 AM in reply to: engqld
LOFT command can also come in handy for these types of calculations.
3D AutoCAD Pipework - http://www.HerculeDesign.com/
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
