AutoCAD 2010/2011/2012
Active Member
mattsears18
Message 1 of 3 (1,780 Views)
How can I calculate cut and fill?
1780 Views, 2 Replies
07-14-2011 06:17 PM
I've used autocad for a while, but I've never created surfaces or anything. Right now I'm using autocad 2011, but I can get civil 3D if need be.
I have a file with existing contours and proposed contours. How can I make 3d surfaces and calculate the cut and fill?
Many thanks!
Member
engqld
Message 2 of 3 (1,771 Views)
Re: How can I calculate cut and fill?
07-14-2011 08:58 PM in reply to: mattsears18
The way I would do this would be by creating the two surfaces in AutoCAD Civil 3D both being a Tin Surface with the appropriate elevations as per the countour heights. Once you have both surfaces you can then create a Tin volume which you set a base and comparison surfaces once this is created under go to surface properties - statistics - volume this will give you a cut fill and net volume.
Hope this helps
Message 3 of 3 (1,753 Views)
07-15-2011 07:09 AM in reply to: engqld
LOFT command can also come in handy for these types of calculations.
3D AutoCAD Pipework - http://www.HerculeDesign.com/
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
