AutoCAD 2010/2011/2012
Member
Mallen2008
Message 1 of 5 (156 Views)
Help with importing a polyface mesh.
156 Views, 4 Replies
01-19-2012 08:58 AM
I am trying to import a Polyface Mesh of a road plan to use in Terramodel.  Terramodel handles .dwf and .dxf perfectly, but I seem to be having trouble preserving the elvations when importing.  The polyface mesh imports in as polylines and without preserving the given elvations.  I have used autocad in the past and have acess to Autocad Civil 3d 2012 if need be.
Is there an import tool or command I am missing or unaware of that will allow the import to take place sucessfully?
*Expert Elite*
Patchy
Message 2 of 5 (152 Views)
Re: Help with importing a polyface mesh.
01-19-2012 09:36 AM in reply to: Mallen2008
Let's see it (attach whatever you have here)
Member
Mallen2008
Message 3 of 5 (147 Views)
01-19-2012 10:02 AM in reply to: Mallen2008
Unfourtantly I do not have permission to post the file as it contains sensitive information. I know this decreases the possiblity of finding an answer.  The file is just a surface of a road created in autocad is their anything else I could provide that would help besides the file? Thanks.
*Expert Elite*
Patchy
Message 4 of 5 (137 Views)
01-19-2012 10:14 AM in reply to: Mallen2008
Download civil3d and export it out.
Member
Mallen2008
Message 5 of 5 (132 Views)
01-19-2012 10:48 AM in reply to: Patchy
I seem to be getting somewhere with Civil3d. Im going through all the file types that terramodel supports trying to find a compitable export. Right now a .dgn file (MicroStation) has had the best results. I have been able to bring in the topo, but the polyface mesh figure is "not compatible with the current drawing file... If you continue exporting, it will be scaled down to be within the size limits of the new format" selecting differant seed files from the drop down menu has the same results.
We where thinking that an .xml file would be our best bet, but when we select that option the cmd prompt reads that "No LandXML compatible objects found".
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
