AutoCAD 2010/2011/2012
Member
Pe-Kor
Message 1 of 14 (8,054 Views)
Accepted Solution
Heidi Module load error
8054 Views, 13 Replies
11-21-2011 03:25 AM
Know someone what to do if AutoCAD 2012 started with follows error?
"The configured Heidi driver cannot be loaded. Switching to default software driver."
I trought set the new plotter file with plotter manager but without succes.
AutoCAD 2011is going without problem.
Thanks for help
*Expert Elite*
Alfred.NESWADBA
Message 2 of 14 (8,044 Views)
Re: Heidi Module load error
11-21-2011 10:44 AM in reply to: Pe-Kor
try command _3DCONFIG ==> (button) "Manual Tune" and disable "Hardware Acceleration".
If that didn't work, you could try to install the servicepack (if you haven't yet).
What graphiccard do you have in your system?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Member
Pe-Kor
Message 3 of 14 (8,013 Views)
11-28-2011 07:08 AM in reply to: Alfred.NESWADBA
Hello, Alfred
thank you for your answer. It help, but I don't know why I must draw without hardware acceleration and support. The ACAD 2011 works excelent with full support of my graphic cart. I have Nvidia FX 1500. I downoaded the last driver for ACAD 2012  recomended from Autodesk on the web - 265.70 - but without succes too.
I have one question more:
Do you know system variable for switch on the dialog window (s)? Iif I will open the drawing of edit the block with attributes then come only command line to the action en it is not prety to work.
Thank you very much for answer.
Petr
*Expert Elite*
Alfred.NESWADBA
Message 4 of 14 (8,003 Views)
11-28-2011 07:47 AM in reply to: Pe-Kor
You don't need to have it disabled, try to reactivate it now, maybe it will work. Sometimes when installing a service pack for AutoCAD or when installing a new driver of the gc that deactive/re-activate is a good point to get rid of some config-data-loss in AutoCAD:
I hope that you didn't install the nVidia performance driver ==> if so try to deinstall it (and maybe a repair-install of AutoCAD may be necessary.
For opening/saving drawings it's FILEDIA (look also >>>here<<<).
For editing block-attributes there are the following sysvar's to check:
  • ATTDIA
  • ATTREQ
  • DBLCLKEDIT
  • PICKFIRST
HTH, - alfred -
Alfred NESWADBA
shiny.stephen
Message 5 of 14 (7,962 Views)
12-05-2011 03:26 AM in reply to: Alfred.NESWADBA
There are various suggestions posted on the forum on this issue. I understand that when launching AutoCAD 2012, it shows the error "Heidi Module Load Error. The configured Heidi driver cannot be loaded. Switching to default software driver."
After a bit of research with our development team the original error in this case with the Heidi Module error is a built in safety net. What happens is there is a known issue with Direct X 9 that causes a disconnect between the video card and the operating system when going to a sleep or screen saver mode. AutoCAD disengages from the video card Heidi module when this problem occurs. This is why you get the error.
AutoCAD does this to prevent a crash and loss of information. If it did not disconnect from the Heidi module and use its internal graphics AutoCAD would crash.
Basically this is an installed safety measure to prevent a crash with a known issue between the OS and the video card. Only certain cards have this particular issue when going to the screen saver or sleep mode. While they work properly otherwise this error message is nothing more than an alert and annoying. When the computer comes back from sleep the video card and OS reconnect and everything is put back to normal.
Heidi errors like this have to do with the video driver on your system. Often simply uninstalling and reinstalling the video driver will fix the problem. Aside from getting the current driver from the manufacturer's web site, you can also check your video card and driver against those that we have tested and certified:
http://www.autodesk.com/autocad-graphicscard
*Update graphics cards drivers
*You could also try going to your Options..."System Tab"...Select "Performance Settings"...try turning off Enable Hardware Acceleration...
*Perform a Windows Update to install the available fixes from Microsoft.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Shiny Stephen
Support Specialist
Product Support
Autodesk, Inc.
Member
Pe-Kor
Message 6 of 14 (7,943 Views)
12-06-2011 04:21 AM in reply to: Pe-Kor
Thanks for recomendation. My AutoCAD 2012 works if Enable Hardware Acceleration is OFF only.
I uninstaled the graphic driver and reistalled new one but the problem is the same.
The switch off some parts of the hardware acceleration make the colapse of AutoCAD.
If I modified the dimesion style in dimension style manager then it's was wery dificult work. After each clic of the mouse come the window with error message.
I work more efficiently with AutoCAD 2011.
I hope that new version of the AutoCAD will be better then 2012.
New Member
tcerina
Message 7 of 14 (7,909 Views)
12-09-2011 03:38 AM in reply to: Pe-Kor
I have exactly the same problems as other users. I am very dissapointed with this "version" generally, so I have to use  version 2011. I hope that the new version better. In fact, you dont have to change anything in older version, we will pay anyway our subscription. Rearranging the icons and commands is very unnecessary.
Distinguished Contributor
damo3
Message 8 of 14 (7,885 Views)
12-11-2011 05:40 PM in reply to: shiny.stephen
just luck that i stumbled across this thread. i came across this error just a few days ago for the first time, caused by 'switching users' in windows 7,  so thanks for the information Shiny.
Employee
jchase123
Message 9 of 14 (7,856 Views)
12-12-2011 08:22 PM in reply to: damo3
Hi all,
The Heidi Module load error can sometimes be fixed by reinstalling the DirectX components that are included on the AutoCAD installation disc. I have seen this problem a few times in the past and it can manifest itself a few different ways. If some of the DirectX components which are required to run get uninstalled or are corrputed than the hardware driver will not be able too run.
On the AutoCAD Disc:
\\CDROM1\3rdParty\DirectX\
I am not ensuring this will fix your issue, only if the problem stems from missing DirectX dependencies.
Best Regards,
Justin Chase
AutoCAD QA Engineer
Member
Pe-Kor
Message 10 of 14 (7,720 Views)
01-02-2012 10:44 PM in reply to: Pe-Kor
Possible solution:
I removed and complete new instaled AutoCAD 2012 from installation CD and it work without error message.
The graphic driver is accepted too with full support.
SP-1 download OK too.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
