AutoCAD 2010/2011/2012
Active Member
chris
Message 1 of 20 (314 Views)
Have to reload SteelPLUS every time I restart AC2012
314 Views, 19 Replies
08-08-2011 11:43 AM
For some reason I have to reload SteelPLUS thru menuload every time I open AC2012.  It will not stay in the list and reload itself (it is completely gone when I open the dialog box).
I have tried repairing thru the "add/remove programs" screen and that didn't work.
I found a similar thread for AC2007, but the links didn't work anymore, so it was no help.
Patchy
Message 2 of 20 (308 Views)
Re: Have to reload SteelPLUS every time I restart AC2012
08-08-2011 11:55 AM in reply to: chris
Was it part of and sold by Autodesk?
Active Member
chris
Message 3 of 20 (305 Views)
08-08-2011 12:06 PM in reply to: Patchy
Not that I'm aware of.  I have 3 other machines that reload it just fine, but I can't figure out what the difference is.
Patchy
Message 4 of 20 (299 Views)
08-08-2011 12:22 PM in reply to: chris
After menuload and load the cuix did you do "Save Current As..."
Active Member
chris
Message 5 of 20 (295 Views)
08-08-2011 12:48 PM in reply to: Patchy
No.  Where would I do that?  I didn't have to with the other 3 machines.
Patchy
Message 6 of 20 (292 Views)
08-08-2011 12:58 PM in reply to: chris
command: WSSAVE
if everything running like they should, half of the problems here would never exist :smileyvery-happy:
Active Member
chris
Message 7 of 20 (288 Views)
08-08-2011 01:09 PM in reply to: Patchy
Should I create a new workspace or choose one from the drop-down list?  Options:
     3D basics, 3D modeling, autocad classic, then each has a duplicate with "migrated from ac2011, 2D drafting & annotation migrated from ac2011, drafting & annotation
If I choose one from the list it says it already exists, do I want to replace?
If I create my own, how would I update ac2012 to use that workspace?
Patchy
Message 8 of 20 (286 Views)
08-08-2011 01:25 PM in reply to: chris
You can try put new name on it, it should stick to that workspace the next time you start autocad.
It always worked for me.
If your is corrupted, copy all .CUIX from other machines to yours and test it out.
Active Member
chris
Message 9 of 20 (280 Views)
08-08-2011 01:32 PM in reply to: Patchy
That did not work.  I should have mentioned that SteelPLUS uses a .mns file; if that makes any difference.
Patchy
Message 10 of 20 (276 Views)
08-08-2011 01:38 PM in reply to: chris
Why don't you compare your .mns with the other PC
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
